12 years agoTrying to compile linux for Cyclone V Soc dev board - errors
I all, I get the following errors when I am following the steps on http://www.rocketboards.org/foswiki/documentation/alterasocdevelopmentboardyoctogettingstarted
ERROR: Failed to obtain external Linaro toolchain version: Execution of '/opt/altera-linux/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux/bin/arm-linux-gnueabihf-gcc -v' failed: command not found ERROR: Failed to obtain external Linaro toolchain version: Execution of '/opt/altera-linux/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux/bin/arm-linux-gnueabihf-gcc -v' failed: command not found ERROR: Execution of event handler 'external_linaro_toolchain_version_handler' failed Traceback (most recent call last): File "external_linaro_toolchain_version_handler(e)", line 12, in external_linaro_toolchain_version_handler(e=<bb.event.ConfigParsed object at 0x3b5ee50>) File "external-linaro-toolchain-versions.inc", line 4, in elt_get_gdb_version(d=<bb.data_smart.DataSmart object at 0x2aed510>) NameError: global name 'CmdError' is not defined WARNING: Host distribution "Ubuntu 12.04.3 LTS" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution. As far as I can tell, the paths it says it cannot find do exist. When I am in the correct directory, and run any files here, it tells me the file doesnt exist - odd that given its in the file list... I have Ubuntu running on a VM inside windows.5 Replies
ahh scratch that - I didnt have the 32 bit libraries installed!
--- Quote Start --- ahh scratch that - I didnt have the 32 bit libraries installed! --- Quote End --- I encountered the same error. Can you please tell me which 32 bit libraries you're referring to? I was following the instructions from this site (http://www.rocketboards.org/foswiki/documentation/alterasocdevelopmentboardyoctogettingstarted) where I encountered the error. I'm using the SocKit board. Am I doing the right thing? I have added a screenshot and the log.txt (copied from console) of the error for you reference. - Altera_Forum
running:
sudo apt-get install ia32-libs got rid of the errors. - Altera_Forum
Now when I run the next steps on the same website:
source ~/yocto/altera-init ~/yocto/build all I get is the following error: ZSH_NAME: Undefined variable. Any ideas? - Altera_Forum
Use bash instead of zsh
