17 years agoTruetype font loading problem
I am trying to load in a truetype font, which is the "lt1-r-omega-serif.ttf" that is in the build. This font is located in "/usr/fonts/truetype/lt1-r-omega-serif.ttf" on the target system. Thi...
17 years ago<div class='quotetop'>QUOTE (schaney @ Sep 4 2009, 07:31 AM) <{post_snapback}> (index.php?act=findpost&pid=23746)</div>
--- Quote Start --- Yes, the file is in the file system. It's located in the directory "/usr/fonts/truetype/lt1-r-omega-serif.ttf" Do you know if I have to set any special permissions for the font file? Any other suggestions of things to look at would be greatly appreciated.[/b] --- Quote End --- I had the same problem and I think the solution was to clean the microwin (make clean user/microwin or something like this). I think it worked for me. In my case the system continued giving me the same error (i think hippo said tha it was a code error) but the font was correctly loaded. Sorry for not to be more precise in my answer. I hope it will help you!
