16 years agoTroubles in running Linux MMU on NDK 2C35:
Hi All, I'm trying to run Linux on Altera's NDK 2C35 and encounter some troubles. - on first, I had to rename the RAM device from "ddr_sdram0" to "ddr_sdram" - on 2d, I had compilation erro...
16 years agoI suppose that does not solve the problem, but the ALTERA UART will not work decently with Linux, as it needs too low interupt latency on receivie, You need to use the FIFOED UART. (It uses the same Kernel driver.)
-Michael
