15 years agoTrouble with uClinux + Igor Avalon MAC + National Semiconductor DP83848
Thanks in advance for any help. I've got a custom built board with a Cyclone II connected to a National Semiconductor DP83848 Prototype board. I have all the MII signals routed to the FPGA. ...
15 years ago --- Quote Start --- I'm not sure about the gor Mac + DP83848 combination, but the TSE and SLS driver + DP83848 is working fine. Did you check the phy_addr? I assume you need to change it to match with your board or device setting. I think the default for the 83848 is 18. You might want to double check it. --- Quote End --- Thank you for the reply... I just figured out that the NEEK has what I need including a full Linux BSP. Unfortunately their downloads are password protected and they have not yet responded to my request for access. So since you have made this work and were kind enough to respond, a couple more questions. When you say "SLS Driver" is that different from the "TSE Driver" options that appear in the kernel build? I built the kernel with the TSE driver enabled but it never booted. I built kernels with the igor mac enabled and they booted but were never functional. Does the SLS reference Linux material come in the package with the NEEK? I have not yet purchased my NEEK but that might push me over the edge. Thanks for your helpful answers, twice you've answered my questions. David
