15 years agoTrouble with uClinux + Igor Avalon MAC + National Semiconductor DP83848
Thanks in advance for any help. I've got a custom built board with a Cyclone II connected to a National Semiconductor DP83848 Prototype board. I have all the MII signals routed to the FPGA. ...
15 years agoI'm not sure about the gor Mac + DP83848 combination, but the TSE and SLS driver + DP83848 is working fine.
Did you check the phy_addr? I assume you need to change it to match with your board or device setting. I think the default for the 83848 is 18. You might want to double check it.
