16 years agoTrouble with "Try Out uClinux"
Everything works fine until: >nios2-download -g images/zImage (except I use the image and .sof provided) I've tried: -DE2(2C35) and DE1 dev boards -Ubuntu and CentOS I always get ...
16 years agook, so for your statisfaction:
>jtagconfig 1) USB-Blaster [USB 3-1.3] 020B40DD >nios2-download <path>/zImage_DE2_NIOS_HOST_MOUSE_VGA_v1.6 --go --instance=0 --device=1 There are no Nios II CPUs with debug modules available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary. ...and because I'm using this example from the wiki, I can almost guarantee you that there is only one CPU. This is not the problem.
