16 years agoTrouble with creating multiprocessor Nios II system with shared memory
Hello, I have created a multiprocessor Nios II system with two cpus sharing on-chip memory . The cpu1 runs a TCP/IP stack(controlled by ucosII) and accept commands from cpu2 I am using the...
16 years agoThe problem “another application is using the target processor ”would not occur when the project run in Altera DE2 board, Quartus II 8.0 and Nios II IDE 8.0.
Could you tell that why?Thanks!
