21 years agotrouble with compactflash
I am currently trying to get the compact flash component to work with my 1C20 dev board from altera. I am using the linux_time_limited.sof core, and I have successfully compiled the kernel with vfat...
21 years agoHi jonv,
can you tell us your kernel configuration for ATA/ATAI/MFM/RLL support? You need enable the following: <div class='quotetop'>QUOTE </div> --- Quote Start --- Enhanced IDE/MFM/RLL disk/cdrom/tape/floppy support Include IDE/ATA-2 DISK support Use multi-mode by default generic/default IDE chipset support Other IDE chipset support Altera CF (IDE mode) interface (Avalon bus) support[/b] --- Quote End --- wentao microtronix
