20 years agoTrouble of NIOS2's timer interrupt
HI everyone i have purchased the NIOS2 evaluate board--EP1C12 from the Altera. and i program a timer interrupt routine to create a square wave based on the evaluate board's standard design. my...
20 years ago --- Quote Start --- originally posted by jesse@Dec 10 2005, 03:53 AM without floating point hardware, a set of software emulation libraries is used when you use float numbers in a program. these tend to be very, very slow, but they do work.
if you want to speed up floating point arithmetic, there are some custom instruction examples posted in the "projects" are of this forum which may be useful.
in addition, when writing interrupt handling code it is recomended in the altera software developer's manual that interrupt service routines be as short and efficient as possible. it is far better, for example, for the interrupt routine to set a pointer or signal so that some other (non-interrupt task) can then go perform the slow calculation.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11459)
--- quote end ---
--- Quote End --- Thanks, Jesse i will try it again. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Best Regards
