16 years agoTrouble compiling Syslib of NIOS2 App
Hi, a while ago I created a little design containing a NIOS 2 and some peripherals (using Quartus II 9.0 and the SOPC Builder on Windows XP Pro / 32 Bit) . I also wrote some programs to learn h...
16 years agoWhat I posted is the 1:1 ouput of "make -n"
The linebreak is already in there. It is also there for the following commands (which are not executed due to the error):
echo Compiling alt_alarm_start.c...
mkdir -p obj/
nios2-elf-gcc -xc -MD -c -DSYSTEM_BUS_WIDTH=32 -DALT_NO_INSTRUCTION_EMULATION -I.. -Isystem_description -I
I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_timer/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_timer/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_pio/inc -I/cygdrive/d/projekte/axe_work/rtl/eth_ocm/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/eth_ocm/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25int/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25int/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_epcs_flash_controller/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_epcs_flash_controller/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25ext/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25ext/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_uart/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_uart/inc -I/cygdrive/d/altera/90/ip/altera/nios2_ip/altera_nios2/HAL/inc -I/cygdrive/d/altera/90/nios2eds/components/altera_hal/HAL/inc -DALT_SINGLE_THREADED -DALTERA_TRIPLE_SPEED_MAC -D__hal__ -pipe -DALT_DEBUG -O0 -g -Wall -mhw-mul -mno-hw-mulx -mno-hw-div -o obj/alt_alarm_start.o /cygdrive/d/altera/90/nios2eds/components/altera_hal/HAL/src/alt_alarm_start.c
echo Compiling alt_busy_sleep.c...
mkdir -p obj/
I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_timer/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_timer/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_pio/inc -I/cygdrive/d/projekte/axe_work/rtl/eth_ocm/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/eth_ocm/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25int/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25int/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_epcs_flash_controller/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_epcs_flash_controller/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25ext/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25ext/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_uart/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_uart/inc -I/cygdrive/d/altera/90/ip/altera/nios2_ip/altera_nios2/HAL/inc -I/cygdrive/d/altera/90/nios2eds/components/altera_hal/HAL/inc -DALT_SINGLE_THREADED -DALTERA_TRIPLE_SPEED_MAC -D__hal__ -pipe -DALT_DEBUG -O0 -g -Wall -mhw-mul -mno-hw-mulx -mno-hw-div -o obj/alt_busy_sleep.o /cygdrive/d/altera/90/ip/altera/nios2_ip/altera_nios2/HAL/src/alt_busy_sleep.c
echo Compiling alt_close.c...
mkdir -p obj/
I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_timer/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_timer/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_pio/inc -I/cygdrive/d/projekte/axe_work/rtl/eth_ocm/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/eth_ocm/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25int/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25int/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_epcs_flash_controller/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_epcs_flash_controller/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25ext/HAL/inc -I/cygdrive/d/projekte/axe_work/rtl/AX25ext/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_uart/HAL/inc -I/cygdrive/d/altera/90/ip/altera/sopc_builder_ip/altera_avalon_uart/inc -I/cygdrive/d/altera/90/ip/altera/nios2_ip/altera_nios2/HAL/inc -I/cygdrive/d/altera/90/nios2eds/components/altera_hal/HAL/inc -DALT_SINGLE_THREADED -DALTERA_TRIPLE_SPEED_MAC -D__hal__ -pipe -DALT_DEBUG -O0 -g -Wall -mhw-mul -mno-hw-mulx -mno-hw-div -o obj/alt_close.o /cygdrive/d/altera/90/nios2eds/components/altera_hal/HAL/src/alt_close.c
echo Compiling alt_dcache_flush.c...
and so on...
Could it be connected to the files being included for accessing the HAL ? Where does this "search and generate the nios-elf-gcc command"-process take place?
