15 years agoTriple-Speed Ethernet with ksz8893
I want to use the mii of ksz8893 connect to Triple-Speed Ethernet ,but it cannot work. my socket can listenning, but i cannot ping from pc.please tell me what should i do?
15 years agoInterNiche Portable TCP/IP, v3.1
Copyright 1996-2007 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Could not locate flash sector with MAC address. Static IP Address is 192.168.1.30 prepped 1 interface, initializing... [tse_mac_init] Marvell 88E1111 Marvell Quad PHY 88E1145 National DP83865 National DP83848C KSZ8893MQL INFO : TSE MAC 0 found at address 0x00000000 INFO : PHY KSZ8893MQL found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... WARNING : PHY[0.0] - Auto-Negotiation FAILED INFO : PHY KSZ8893MQL found at PHY address 0x02 of MAC Group[0] ERROR : PHY[0.0] - Mapping of PHY to MAC failed! Make sure the PHY address is defined correctly in tse_mac_device[] structure, and number of PHYs connected is equivalent to number of channel INFO : PHY KSZ8893MQL found at PHY address 0x03 of MAC Group[0] ERROR : PHY[0.0] - Mapping of PHY to MAC failed! Make sure the PHY address is defined correctly in tse_mac_device[] structure, and number of PHYs connected is equivalent to number of channel WARNING : MAC Group[0] - Number of PHY connected is not equal to the number of c hannel, Number of PHY : 3, Channel : 1 INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... WARNING : PHY[0.0] - Auto-Negotiation FAILED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link not yet established, restart auto-negotiation... INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... WARNING : PHY[0.0] - Auto-Negotiation FAILED WARNING : PHY[0.0] - Link could not established ERROR : PHY[0.0] - Auto-Negotiation not completed! Gigabit = 0, Duplex = Full OK, x=5, CMD_CONFIG=0x01000000 MAC post-initialization: CMD_CONFIG=0x05000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created IP address of et1 : 192.168.1.30 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4)
