10 years ago
Trigger and counter.
I'm trying to implement a counter that counts down when it recieves a trigger pulse from the hardware (in this case, it's a short burst of AC, in the order of a few hundred µs), which keeps an LED on. I have no idea why my code isn't working, I'm pretty new to C programming. Any help greatly appreciated.
if (trigger_reg == 1){                                //goes to 1 when the AC signal reaches the trigger module threshold
          int countdown = 10000000;                            //arbitrary value
          while (countdown > 0){                                 //use this loop to keep the LED on longer than the trigger pulse, so the user can see it
              green_leds=1;
              countdown--;
      } else {
          green_leds=0;
-N
    A wild guess here.
    Compile with no optimization at all.
    The optimizer may be shrinking all the code to almost nothing if the variables are not declared volatile.
    You should implement this circuit in hardware - verilog or vhdl.
    --- Quote Start ---
    --- Quote End ---
    What if the OP wants to make a bigger design and this is just a first step? Yes a HDL solution would work, but you need to be able to understand the languages and hardware design, which not everyone does or wants to invest in.
