14 years agoTransferring data from a HDL to the Nios II processor
Hello, I have a HDL module which is connected to the Avalon bus as a slave component. The component has a FIFO with a length of 4096 * 32 bits values which the processor should read out perdiod...
12 years agoHi,StMartin81
Have your problems solved?I have met the same problem with you.
