14 years agoTransferring data from a HDL to the Nios II processor
Hello, I have a HDL module which is connected to the Avalon bus as a slave component. The component has a FIFO with a length of 4096 * 32 bits values which the processor should read out perdiod...
13 years agoHello StMartin81,
Did you finish your project? I am also encountering this issue. I also want to transfer data from HDL to Nios II memory. If you experienced it, can you tell me what I should do to get data to Nios II system?
