16 years agotransfer from nios to 64-bit component
Hello, I am currently working on my own slave component. I've written and tested the 32-bit input version and it worked well. Now I have 64-bit input version. I know that nios cpu handles 32-...
16 years agothanks for answer.
You're right I'am a little bit confused about this solution. byteenable should be 8bytes, I understand. but how all operation of data transfer should look like? To send 64-bit vector from nios to slave input do i have to do it like this: set the byteenable to 0000_1111 send 64-bit data (the master will send first 32-bit) then set the byteenable to 1111_0000 send 64-bit data (the master will send last 32-bit) am i right or did i missunderstood the whole process? Maybe there is a easier solution for such transfer?
