20 years agotransfer from internal to external memory
Hallo, I am new in the use of the nios system and tried to transfer a program using up to now internal memory of the cyclon chip to extenal memory. It seems to fail to change the reset / exeption ...
20 years agoHI
If you run the programme from Nios IDE and it run but not dispay any message means , nios cpu does not working . So first check the simple "hello world" programme in nios ide and then check is it working or not. then go ahead Thanks slsnios
