20 years agotransfer from internal to external memory
Hallo, I am new in the use of the nios system and tried to transfer a program using up to now internal memory of the cyclon chip to extenal memory. It seems to fail to change the reset / exeption ...
20 years agoDear slsnios
it seems to work fine, but after starting the software from nios ide i got the message nios terminal "connected to hardwware target using jtag uart on cable" then "Use the IDE stop button or ctrnl-C to terminate" and that´s it the program didn´t visually start ( no output at all ).
