11 years agoTRACE Debug on Cyclone V HPS - has anyone used DSTREAM
I am trying to use the TRACE Port peripheral on the HPS in a Cyclone V SE device. I cannot seem to get the TRACE signals coming out of the device properly to run the TRACE Capture using the DSTREAM ...
11 years agoHi Adam,
The "Check Board" should make sure that the pins are correctly configured for tracing. The latest version of the tools seems to have some trouble detecting that. This is a known issue, that is being investigated. Since you already know that the Preloader configured the pins accordingly, you do not actually need this check. Regards, Radu
