11 years agoTRACE Debug on Cyclone V HPS - has anyone used DSTREAM
I am trying to use the TRACE Port peripheral on the HPS in a Cyclone V SE device. I cannot seem to get the TRACE signals coming out of the device properly to run the TRACE Capture using the DSTREAM ...
11 years agoHi Radu,
Thank you for the reply! That video had the little bit of information I was missing... I needed to un-check the box labeled "Check board is correctly configured before attempting to capture trace in DSTREAM buffer" BTW, do you know what the "Check board ..." is actually looking for before starting to use TRACE?? Thanks, Adam
