13 years agoToolchain compile problems on RHEL 6.3
I am having some problems compiling the Nios2 toolchain on RHEL 6.3 64bit and need some advice. In a nutshell, the gcc3 build in the tool chain produces a segmentation fault during the compile. ...
13 years ago --- Quote Start --- If that is the host gcc faulting, then it is a bug in the installed gcc itself, not in gcc sources being built. --- Quote End --- IIRC the crash comes up in the bootstrap compiler built and used as part of the toolchain build, not in the installed gcc. --- Quote Start --- If you are compiling gcc for nios, I'd consider applying the patches I put on the wiki - especially if you need to the code to run as fast as possible. --- Quote End --- Link please?
