20 years agoto use user apps ported from uClinux-dist
Hi,Hippo
I want to use user apps ported to uClinux from uClinux-dist. The problem is :make: Leaving directory `/home/melvin/uClinux-dist/include'
make: Entering directory `/home/melvin/uClinux-dist/lib'
Making symlinks in lib/
make: Leaving directory `/home/melvin/uClinux-dist/lib'
make: Entering directory `/home/melvin/uClinux-dist/include'
find . -depth -type l -a ! -name Makefile | xargs rm > /dev/null 2>&1 || exit 0
find . -depth -type d | xargs rmdir > /dev/null 2>&1 || exit 0
Making symlinks in include/
Making include/c++ symlink to compiler c++ includes
make: Entering directory `/home/melvin/uClinux-dist/user'
for i in dhcpd games ping /home/melvin/uClinux-dist/vendors/Altera/nios2nommu/. /home/melvin/uClinux-dist/prop; do
if ; then
touch $i/.sgbuilt_user;
make -C $i || exit $?;
fi;
done
make: Entering directory `/home/melvin/uClinux-dist/user/dhcpd'
make: Nothing to be done for `all'.
make: Leaving directory `/home/melvin/uClinux-dist/user/dhcpd'
make: Entering directory `/home/melvin/uClinux-dist/user/games'
for i in dummy; do
|| make -C $i || exit;
done
make: Leaving directory `/home/melvin/uClinux-dist/user/games'
make: Entering directory `/home/melvin/uClinux-dist/user/ping'
make: Leaving directory `/home/melvin/uClinux-dist/user/ping'
make: Entering directory `/home/melvin/uClinux-dist/vendors/Altera/nios2nommu'
dirs= include lib include user;
for i in $dirs; do make -C $i || exit; done
/bin/sh: include: command not found
make: Leaving directory `/home/melvin/uClinux-dist/vendors/Altera/nios2nommu'
make: Leaving directory `/home/melvin/uClinux-dist/user' I just select dhcpd and ping ,don't select games . Please give me some advice. Thank you!!1 Reply
I repeated the tests. It did enter the game sub dir, but build nothing.
So don't worry about it. Try "make subdirs", "make romfs", and check the romfs/bin .
