20 years agoTo Nios II/s or f processor speed
Hi all,
During building Nios II/standard or Nios II/full_featured, I have used the clock at 50MHz. According to Altera, the Stratix pro board will have 200 DMIPS speed with 1.17 DMIPS/MHz. Can I assign the clock speed to 160 or 200 MHz. Thanks & regard, Goutam1 Reply
--- Quote Start --- originally posted by goutam_kumar@May 5 2006, 04:44 PM hi all,during building nios ii/standard or nios ii/full_featured,
i have used the clock at 50mhz.
according to altera, the stratix pro board will have 200 dmips speed with
1.17 dmips/mhz.
can i assign the clock speed to 160 or 200 mhz.
thanks & regard,
goutam
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15078)
--- quote end ---
--- Quote End --- Yes, you can assign it in sopc builder. If you have ddr sdram, update the ddr sdram component toolbench in sopc build to update timing. You have to adjust the pll for clock gen, too. Then check the timing report to see if the timing request meet.
