20 years agoTo Nios II/s or f processor speed
Hi all, During building Nios II/standard or Nios II/full_featured, I have used the clock at 50MHz. According to Altera, the Stratix pro board will have 200 DMIPS speed with 1.17...
20 years agoYou can certainly try. I currently have 5 NIOS processors in a system running at 160 MHz and have had several run at 200MHz. The problem you will likely run into is meeting timing when you actually compile the firmware in Quartus. A lot of the peripherals will have a hard time running at these speeds. Onchip memory that is allocated using M4K blocks will have a hard time keeping up with these speeds. The FPGA you are using will affect this as well. But by all means, give it a shot.
