12 years agotiming problem
Hi everyone : Timequest shows errors, removal slack: http://www.alteraforum.com/forum/attachment.php?attachmentid=9466&stc=1 The timing report is : http://ww...
12 years ago --- Quote Start --- No you are not right as you can see. try registering reset in several locations to reduce fanout. altenatively use synchronous reset but this shifts timing burden to hold which is rare. --- Quote End --- hi thanks ! i am new to timing problems, can you explain more? or can you give me a document? thanks!
