12 years agoTiming measurement
Hi, Please i try to measure timing of block on the Nios through alt_timestampe() function. It work fine :), but my probleme why when i measure a block that's contain for example 10 instruction...
12 years agoThe difference between your expected/actual results could be lots of things (interrupts, memory access, etc.)
See this appnote for a good introduction to some of the techniques. http://www.altera.com/literature/an/an391.pdf And you can also use the NIOS signaltap plugin. http://www.altera.com/literature/an/an446.pdf
