21 years agotime limited sof file and flash programmer
Can I use a time limited sof file with the IDE Flash programmer? Currently I use the Quartus Programmer to get the sof on the board and the run my program from the IDE. I tried to put the sof into the flash but the programming for the sof fails, only the elf file will be programmed to the flash. When I do the same with a standard sof from the example designs the programming succeeds. I also tried the shell and nios2-flash-programmer with the time limited sof file but the command does never return and there is no error message.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
Hello, I have exactly the same problem but i can't solve it !!! Have you respect the minimal frequency ? (50 mhz) Have you respect the same names for the target board and for the actual project ? Can anyone help us ???? please !!!! - Altera_Forum
Hi all,
the time limited sof file can't be downloaded in flash. Otherwise it couldn't be time limited http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
