19 years agotime limited core
hello,
I bought a nios development kit stratix edition then required and obtain the license. Then i'm trying to create a design, using a niosII processor and a sdram controller. But it generate just a time limited .sof. Is it normal? Then when i launch quartus, tehre was written "subscription expire", they ask me to specify a license, whereas i already done it in tools -> license setup. ( my license should expire in march 2008).1 Reply
--- Quote Start --- originally posted by visman@Mar 13 2007, 05:50 AM hello,i bought a nios development kit stratix edition then required and obtain the license.
then i'm trying to create a design, using a niosii processor and a sdram controller.
but it generate just a time limited .sof. is it normal?
then when i launch quartus, tehre was written "subscription expire", they ask me to specify a license, whereas i already done it in tools -> license setup. ( my license should expire in march 2008).
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22249)
--- quote end ---
--- Quote End --- In the same location where you specified your license location there should be a box underneath showing you all the IP cores that your license is valid for. If you don't see Nios II listed then I would contact your sales representative to clear up the issue. The time limited sof file requires you to keep a USB blaster connected to the board and the dialog box that opens after you download the programming file must remain open.
