12 years agoTightly Coupled OnChip DMA
Hi, I've got some very strange 'performance behavior' with a tightly coupled on chip memory used as data storage. In order to speed up my design, I've created a tightly coupled on chip memory w...
12 years agoIs the TCM single or dual port?
If it's a single port ram, then it will definitly stall while the copy takes place. If its a true dual port, you should be able to make it work, just make sure the NIOS is attached to one port and the DMA controller is attached to the other. Pete
