13 years agotightly-coupled memory performance !!
I wanted to compare the performance between cache and tightly-coupled memory. So I did the following experiment: tic call the function() toc tic call the same function() toc I no...
13 years agoThank you dsl, that makes sense. However, is there any trick to force the NIOS-II/f to use the static branch predictor.
