13 years agotightly-coupled memory performance !!
I wanted to compare the performance between cache and tightly-coupled memory. So I did the following experiment: tic call the function() toc tic call the same function() toc I no...
13 years agoThe called function assembly code
05009254 <corner_turn_main>: 5009254: 2015883a mov r10,r4 5009258: 0013883a mov r9,zero 500925c: 00001506 br 50092b4 <corner_turn_main+0x60> 5009260: 40800017 ldw r2,0(r8) 5009264: 3885883a add r2,r7,r2 5009268: 11000017 ldw r4,0(r2) 500926c: 01400784 movi r5,30 5009270: 3145383a mul r2,r6,r5 5009274: 1245883a add r2,r2,r9 5009278: 1085883a add r2,r2,r2 500927c: 1085883a add r2,r2,r2 5009280: 00c14474 movhi r3,1297 5009284: 18e7c604 addi r3,r3,-24808 5009288: 10c5883a add r2,r2,r3 500928c: 11000015 stw r4,0(r2) 5009290: 00c00044 movi r3,1 5009294: 30cd883a add r6,r6,r3 5009298: 00800104 movi r2,4 500929c: 388f883a add r7,r7,r2 50092a0: 317fef1e bne r6,r5,5009260 <corner_turn_main+0xc> 50092a4: 48d3883a add r9,r9,r3 50092a8: 5095883a add r10,r10,r2 50092ac: 00800a04 movi r2,40 50092b0: 48800426 beq r9,r2,50092c4 <corner_turn_main+0x70> 50092b4: 5011883a mov r8,r10 50092b8: 000d883a mov r6,zero 50092bc: 000f883a mov r7,zero 50092c0: 003fe706 br 5009260 <corner_turn_main+0xc> 50092c4: f800283a ret The calling function assembly code: 5008cc8: 04010034 movhi r16,1024 5008ccc: 84062804 addi r16,r16,6304 5008cd0: 84800037 ldwio r18,0(r16) 5008cd4: a009883a mov r4,r20 5008cd8: 50092540 call 5009254 <corner_turn_main> 5008cdc: 84400037 ldwio r17,0(r16) 5008ce0: 8ca3c83a sub r17,r17,r18 5008ce4: 04c000b4 movhi r19,2 5008ce8: 9cc7af04 addi r19,r19,7868 5008cec: 9809883a mov r4,r19 5008cf0: 880b883a mov r5,r17 5008cf4: 000feb00 call feb0 <printf> 5008cf8: 84800037 ldwio r18,0(r16) 5008cfc: a009883a mov r4,r20 5008d00: 50092540 call 5009254 <corner_turn_main> 5008d04: 84000037 ldwio r16,0(r16) 5008d08: 84a1c83a sub r16,r16,r18 5008d0c: 9809883a mov r4,r19 5008d10: 800b883a mov r5,r16 5008d14: 000feb00 call feb0 <printf>
