13 years agotightly-coupled memory performance !!
I wanted to compare the performance between cache and tightly-coupled memory. So I did the following experiment: tic call the function() toc tic call the same function() toc I no...
13 years agoThe calling function is very simple. And it is the called function that has the reading loop.
The called function should be the same for each call, right?
