19 years agoTightly coupled memory and C2H
I have a NIOS application for which using tightly coupled, on-chip memory appears to be offering a nice performance boost. I have a large array of values that I like to reference periodically and ra...
19 years agoJCJB -
Thanks, I think that will help a lot. Clearly the issue that I was struggling with was that the first port on the TCM had a 1:1 connection with NIOS which blocked any other access. I can see where dual port would offer then 2nd path in that I need. That said just two more (hopefully simple) questions. I went looking in all the Altera documentation but came up dry. 1) When I create the 2nd slave port on the tightly coupled memory, what do I connect it to in the SOPC builder? Or do I leave it unconnected as I'm going to reference it in C2H? 2) I'm not familiar with pragma syntax. Any suggestions on what it would be or where I could go to get some documenation on it? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif V
