19 years agoThinner flash driver
Hello, My Nios II code must run from onchip memory so I have a very limited code space to play with. In my system libraries I set "Small C library" and "Reduced drivers" to save some space. ...
19 years agoeliben,
I was in your exact position 6 weeks ago. I started a SR with Altera but we weren't able to find a solution using the HAL. Ultimately, the "solution" suggested by Altera support was to write the flash routines myself. A bit of sample code was provided which got me well on my way. PM me if you are still working on a solution and need this sample code. s
