GHelb
6 years agoThere is a problem using the JTAG UART in 19.1
The instantiation is wh_nios.jtag_uart:
Info: wh_nios.jtag_uart: JTAG UART IP input clock need (sic) ...
The HDL builder looks for wh_nios_jtag_uart and it can't find it:
Error: jtag_uart: Failed to find module wh_nios_jtag_uart
- Ahmed_H_Intel1
Are you seeing this error while running the application or while compiling it?
it seems like there are some files missing.
- GHelb
The error happens inside Platform Designer. It is unable to create the system.
I checked: A design that works in 18.1.1 does not work in 19.1.
- Ahmed_H_Intel1
Ohh, I believe it is a 19.1 issue. I will open an internal ticket to check this and get fixed ASAP. I recommend you to use the 18.1 as it is the most stable version and reliable.
Please accept our apology for this inconvenience.
