21 years agothere can i get any help for S80 dsp board?
the ds_stratix_dsp_bd_pro_1s80.pdf give a method to download a user configuration into flash memory by using Write2Flash.exe utility, and it said: 5. Press SW1 on the board to erase the prev...
21 years ago --- Quote Start --- originally posted by kerri@Dec 22 2004, 04:28 PM do you have a board with amd flash on it?
if so, email me and i can send you the 'solution'.
it's a zip file. so, i can't just type it here.
[email protected] --- Quote End --- Are you using the board labeled ALTERA STRATIX DSP S80 Development Board Rev. 1.2? dsp development board, stratix professional edition (http://www.altera.com/products/devkits/altera/kit-dsp_stratix_pro.html). Incidentally, the photo on that page is incorrect. It shows the S25 board. I might be able to help you with those. Kerri, would you be so kind as to send me your zip file so I can compare it with what I'm using? Our former Altera rep sent me something, but it had shortcuts in it instead of executables. uSoft 1 Altera 0. Thanks. Leslie [email protected]
