21 years agothere can i get any help for S80 dsp board?
the ds_stratix_dsp_bd_pro_1s80.pdf give a method to download a user configuration into flash memory by using Write2Flash.exe utility, and it said: 5. Press SW1 on the board to erase the prev...
21 years agoThank you for this useful information. I also have a ep1s25 dsp board.It's also the same problem.the resource is very limited to these boards. Dose the FAE only update the hardware driver(EPM or Flash)?
I think it's not this tip cause I used TEST program to open the Flash,it's not work that this progress has no relation with the EPM.
