21 years agothere can i get any help for S80 dsp board?
the ds_stratix_dsp_bd_pro_1s80.pdf give a method to download a user configuration into flash memory by using Write2Flash.exe utility, and it said: 5. Press SW1 on the board to erase the prev...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- when i remove JP18 and power up,the seven-segment display F.F., and Press SW1 ,the seven-segment display 33. It can't like the PDF said display 00. and when using Write2Flash.exe to download data,and power up,the seven-segment also display .[/b] --- Quote End --- We have had a brand new stratix dsp kit (i think it was a std device ep1s25 device though not sure) which never worked for flash programming as described in the PDF manual. I dont recall if it had similar diagnostic (Display 33), but our friendly FAE updated the board and now it works again. I am not sure what was updated: the flash or the EPMxxxx config controller, but at least one of them were reloaded. I was not permitted to get a copy of the update code, which anyway would be useless for the PRO board. My advice to you is to contact your altera FAE or whoever you talk to at altera and get a reconfig done. The flash programming works on all the boards (also pro's) we have when following the PDF manual instructions. So in your case something is certainly broken. In this problem I am affraid you are entirely in the hands of altera, as there are no documentation/code of the flash EPMxxxx config controller nor the flash memory layout. I have with much regret and surprise not been able to get this information from MySupport. One one would expect this to be readily available on a dev kit to easy port to custom hardware. The schematic is available in the kit, but not the code. The nios kits do have this information, but they are different from the stratix dsp kits. Needles to say, any information would be appreciated here as this is rather frustrating when, as we are, trying to port nios to the dsp kits. In particular the flash is giving problems for the moment. We have experienced a problem that the WriteToFlash.exe were missing a dll file in ditribution cd, but this is independent of the board erase cycle. regards
