14 years agoThere are no JTAG cables available on your system
Hi! I have the next problem:
When I want to "Run as NIOS II Hardware" example project (Nios II Hardware Development Tutorial) in Console I see: "here are no JTAG cables available on your system which match --cable option you provided (USB-Blaster on localhost [USB-0])" it happens on 63% and then appears the window with the text: " 'Launthing count NIOS II Hardware configuration' has encountered a problem. Downloading ELF Process failed" Anybody can help me? P.S. Forgive me my English...))2 Replies
what is your OS? 32 or 64 bits? Did you install well the diver of USB Blaster? Try this: http://www.altera.com/support/kdb/solutions/rd03062012_414.html Regards - Altera_Forum
32 bits. When I connect USB-blaster to my PC, driver installed automatically. In Quartus II Programmer I can program the device and it works correctly, but in NIOS-II for Eclipse this error happens.
