20 years agothe question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 , uclinux can rightly startup. but, when i use the u-boot to startup the kernel and filesystem of uclinux by the bootm com...
20 years agohi scott:
i have already solved the problem. it is startupping the kernel. in the past : -- I configured u-boot to use the serial UART, and -- I configured the kernel to use the JTAG UART. now : -- I configur u-boot to use the serial UART, and -- I configur the kernel to use the UART. thank you very much for your help! the other question is: U-Boot 1.1.3 (Jan 3 2006 - 10:17:49) CPU : Nios-II SYSID : d4a9fbb0, Mon Dec 19 06:36:32 2005 BOARD : Altera EP-1C6 *** Warning - bad CRC, using default environment why is the "bad CRC"? how to setting environment variety, the problem of "bad CRC" can be solved?
