20 years agothe question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 , uclinux can rightly startup. but, when i use the u-boot to startup the kernel and filesystem of uclinux by the bootm com...
20 years agoMaybe you are using JTAG-UART??
After you linux booted up by u-boot, you should use nios2-terminal in NIOS2 shell to see the log of linux booting. By this way, the linux will work ok.
