20 years agothe question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 , uclinux can rightly startup. but, when i use the u-boot to startup the kernel and filesystem of uclinux by the bootm com...
20 years agohi scott:
"1. How did you create your compressed kernel image?" i use the command to compress the kernel : gzip -9 vmlinux.bin mkimage -A nios2 -O linux -T kernel -C gzip -a 0x00800000 -e 0x00800000 -n 'Linux Kernel Image' -d vmlinux.bin.gz uImage.img mkimage -A nios2 -O linux -T filesystem -C gzip -a 0x00c00000 -e 0x00c00000 -n 'romfs EP1C6' -d romfs.bin.gz romfs.img "2. Did you try booting an uncompressed image? If not please try booting an uncompressed u-boot image file -- let us know if you have the same problem." i use the command according to what you said : mkimage -A nios2 -O linux -T kernel -C none -a 0x00800000 -e 0x00800000 -n 'Linux Kernel Image' -d vmlinux.bin uImage.img mkimage -A nios2 -O linux -T filesystem -C none -a 0x00c00000 -e 0x00c00000 -n 'romfs EP1C6' -d romfs.bin romfs.img $SOPC_KIT_NIOS2/bin/bin2flash --flash=U5 --location=0x00000000 --input=u-boot.bin --output=u-boot.flash $SOPC_KIT_NIOS2/bin/bin2flash --flash=U5 --location=0x00040000 --input=uImage.img --output=uImage.flash $SOPC_KIT_NIOS2/bin/bin2flash --flash=U5 --location=0x00200000 --input=romfs.img --output=romfs.flash and then, i download the three files to the NOR flash by the nios2-flash-programmer. but, when i use the command of "bootm 00040000", the output: ==> bootm 00040000# # Booting image at 00040000 ... Image Name: linux kernel Image Image Type: Nios-II Linux Kernel Image (uncompressed) Data Size: 1053348 Bytes = 1 MB Load Address: 00800000 Entry Point: 00800000 Verifying Checksum ... OK OK have the same problem. i am more confused now. why is not ok when i use the u-boot to startup the uncompressed kernel. if i upload the kernel and romfs to NOR flash, and then, running the nios2-termianl, the output is ok! i feel the question relates the address. because, i am not setting the any address in making the kernel and romfs. but, i do not know how to do. "3. Your image says, "2.6.4 kernel for EP1C6" -- is this correct? Or are you actually using 2.6.11 or higher?" i do not know the version of uclinux kernel, the "2.6.4 kernel for EP1C6" is added at random. in fact, the real version is "linux version 2.6.11-uc0(sl@wst-9faecf0fdb1) (gcc version 3.4.1(altera niosii 5.0 b73))" sorry, i forgot to say: when i make the kernel, i delete: drivers/char/altera_pio_button \ drivers/ide/ide \ drivers/net/smc91111. if i do not this, it is always to wrong when i make the kernel.
