20 years agothe question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 , uclinux can rightly startup. but, when i use the u-boot to startup the kernel and filesystem of uclinux by the bootm com...
20 years agoHi Lucky,
I don't see anything suspicious in your objdump. A few more questions: 1. How did you create your compressed kernel image? 2. Did you try booting an uncompressed image? If not please try booting an uncompressed u-boot image file -- let us know if you have the same problem. 3. Your image says, "2.6.4 kernel for EP1C6" -- is this correct? Or are you actually using 2.6.11 or higher? Regards, --Scott
