20 years agothe question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 , uclinux can rightly startup. but, when i use the u-boot to startup the kernel and filesystem of uclinux by the bootm com...
20 years ago1 reply to Scott
the output of nios2-elf-objdump -h u-boot: u-boot: file format elf32-littlenios2 sections: idx name size vma lma file off algn 0 .text 00017da9 00fc0000 00fc0000 00000094 2**4 contents, alloc, load, readonly, code 1 .u_boot_cmd 000003c0 00fd7dac 00fd7dac 00017e3d 2**2 contents, alloc, load, data 2 .data 00000a6c 00fd816c 00fd816c 000181fd 2**2 contents, alloc, load, data 3 .bss 00003cd4 00fd8be0 00fd8be0 00018c69 2**2 alloc 4 .comment 000007e5 00000000 00000000 00018c69 2**0 contents, readonly the output of nios2-elf-objdump -h vmlinux: vmlinux: file format elf32-littlenios2 sections: idx name size vma lma file off algn 0 .text 000d7aa4 00800000 00800000 00000094 2**3 contents, alloc, load, readonly, code 1 .data 0001c550 008d7ab0 008d7ab0 000d7b38 2**4 contents, alloc, load, data 2 .init 0000d2a4 008f4000 008f4000 000f4088 2**2 contents, alloc, load, code 3 .bss 0000a220 009012b0 009012b0 0010132c 2**4 alloc 4 .sbss 00000022 0090b4d0 0090b4d0 0010132c 2**0 alloc, small_data 5 .eram 00000000 01000000 01000000 0010132c 2**0 contents 6 .romfs .data 00000000 00200000 00200000 0010132c 2**0 contents 7 .comment 00002850 00000000 00000000 0010132c 2**0 contents, readonly 2 i use the custom developing board which is not altera and Microtronix. whether or not i need to port uclinux for my board? 3 can i modify the kernel or filesystem download \ load and entry point address in the memory? if yes, how to do it?
