20 years agothe question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 , uclinux can rightly startup. but, when i use the u-boot to startup the kernel and filesystem of uclinux by the bootm com...
20 years agoHi lucky,
> i make an experiment about using the u-boot to startup the uclinux by the > your said method that folloes as: ... > and then download to NOR flash. I was asking you to run nios2-elf-objdump on u-boot and the kernel ... and post the output in this Nios Forum Topic, so I can see how you have your sections mapped. You should also try booting an uncompressed image. Regards, --Scott
