20 years agothe question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 , uclinux can rightly startup. but, when i use the u-boot to startup the kernel and filesystem of uclinux by the bootm com...
20 years ago1
i make an experiment about using the u-boot to startup the uclinux by the your said method that folloes as: For u-boot $ nios2-elf-strip u-boot $ nios2-elf-objdump -h u-boot For kernel: $ nios2-elf-strip vmlinux $ nios2-elf-objdump -h vmlinux and then download to NOR flash. but, the question is the same to the before question: the cursor winding in the windows and my developing board's led is not winding(maybe die). 2 "Another question: are you using a data cache?" my nios2 is the nios/e(no instruction cache and no data cache).
