20 years agothe question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 ,
uclinux can rightly startup. but, when i use the u-boot to startup the kernel and filesystem of uclinux by the bootm command, the program is always running the half to stop. follows: U-Boot 1.1.3 (Dec 28 2005 - 19:11:13) CPU : Nios-II SYSID : d4a9fbb0, Mon Dec 19 06:36:32 2005 BOARD : Altera EP-1C6 *** Warning - bad CRC, using default environment ==> bootm 0x00040000# # Booting image at 00040000 ... Image Name: 2.6.4 kernel for EP1C6 Image Type: Nios-II Linux Kernel Image (gzip compressed) Data Size: 459971 Bytes = 449.2 kB Load Address: 00800000 Entry Point: 00800000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK my u-boot is downloaded the address of 0x00000000;the kernel of uclinux is downloaded the address of 0x00040000;the filesystem of uclinux is downloaded the address of 0x00150000. my load address is 0x00800000;my entry address is 0x00800000.(0x00800000 is my sdram the base address.) why? can someone help me! thanks!1 Reply
Duplicate thread. Please see:
http://forum.niosforum.com/forum/index.php...wtopic=3105&hl= (http://forum.niosforum.com/forum/index.php?showtopic=3105&hl=) --Scott
