20 years agothe question about the interrutor vertor table
the file of Nios II Software Developer's Handbook_v5 is not explicit. can you help me? 1 all of the interruptor vertor table of nios is how to dispatch in the hardware address like the ...
20 years ago --- Quote Start --- originally posted by lucky@Dec 26 2005, 06:46 AM 1 all of the interruptor vertor table of nios is how to dispatch in the hardware address like the arm from 0x0 to 0xff?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11781)
--- quote end ---
--- Quote End --- Yes, similar but a little bit simpler than ARM... you only have the IRQ pin to which all the software and hardware interrupts are redirected! --- Quote Start --- originally posted by lucky@Dec 26 2005, 06:46 AM 2 how to use the interrutor vertor api of the nios and how to register it and response it ?
--- quote end ---
--- Quote End --- ??? There is an example at page 6-10 of the Nios II Software Developer's handbook... some other examples should be in the examples directory of altera... (just grepping gives some results
pj@TOM /cygdrive/c/altera/kits/nios2_51/examples/software
$ grep -rl alt_irq_register *
board_diag/board_diag.c
count_binary/count_binary.c
tcm/timer_interrupt_latency.c ); other examples (very similar to those available in the Altera Directory) are also available in the demo we distribute with ERIKA Enterprise, in particular the 2 CPU and the FIFO demo available here (http://www.evidence.eu.com/nios2/literature.asp) --- Quote Start --- originally posted by lucky@Dec 26 2005, 06:46 AM 3 have interrutor vertor functions the stable names by yourself ? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11781)
--- quote end ---
--- Quote End --- What you mean with "stable names"? you can link a function you wrote to the interrupt using alt_irq_register... --- Quote Start --- originally posted by lucky@Dec 26 2005, 06:46 AM 4 who has the whole of the interrutor vertor table of nios, and he has the example of using it completed in the program?
--- quote end ---
--- Quote End --- There is only one exception vector, whose address is specified inside SOPCBuilder. Then, there is the ipending register, and all the rest is done in software... bye Paolo
