16 years agoThe problem of SRAM
Hi! I have succeed to display a image on the LCD through my LCD_CORE,thank you for your help. But I still have a problem about the SRAM,The data bus of my SRAM is 16 bit,so I think the data I wr...
16 years agoAvalon-MM tri-state slaves are accessed using byte addresses. Please refer to Avalon Interface Specifications, section 3.6.2. Avalon-MM Tri-State Slave Addressing.
http://www.altera.com/literature/manual/mnl_avalon_spec.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=avalon%20spec I think you have to code your own sram-controller if you want a word access. Jens
