16 years agoThe problem of SGDMA descriptor
Hi: I am trying to use the SGDMA to transfer data,but I find it's hard to write the descriptor.I spend o lot of time to read the desgin example SG-DMA,it's hard to be understand. Is there so...
16 years agothank you for your suggestion.
but i want to know the Scatter-Gather DMA Controller Core PDF shows the mode of the descriptor data struct is: typedef struct { alt_u32 *read_addr; alt_u32 read_addr_pad; alt_u32 *write_addr; alt_u32 write_addr_pad; alt_u32 *next; alt_u32 next_pad; alt_u16 bytes_to_transfer; alt_u8 read_burst; /* Reserved field. Set to 0. */ alt_u8 write_burst;/* Reserved field. Set to 0. */ alt_u16 actual_bytes_transferred; alt_u8 status; alt_u8 control; } alt_avalon_sgdma_packed alt_sgdma_descriptor; but in the code i didn't find the structure. thank you very much.
