16 years agoThe problem of multi_cycle custom instruction
Hi! I want to learn the multi_cycle custom instruction,so I write an code randomly. but the instruction didn't work in the NIOS IDE.I cann't find the error of the code,please help me. libr...
16 years agoThis is only template for guidance(haven't checked syntax)
library ieee;
use ieee.std_logic_1164.all;
entity move is
port(
dataa: in std_logic_vector(31 downto 0);
datab: in std_logic_vector(31 downto 0);
result: out std_logic_vector(31 downto 0);
clk: in std_logic;
clk_en :in std_logic;
start: in std_logic;
reset: in std_logic;
done: out std_logic
end move;
architecture behave of move is
signal t: std_logic_vector(3 downto 0);
signal a: std_logic_vector(31 downto 0);
signal b: std_logic_vector(31 downto 0);
begin
process(clk,reset)
begin
if(reset = '1')then
a <= (others => '0');
b <= (others => '0');
t <= (others => '0');
done <= '0';
result <= (others => '0');
elsif(clk'event and clk='1')then
if(clk_en = '1')then
if(start = '1')then
a <= dataa;
b <= datab;
t <= "0000";
done <= '0';
end if;
if(t < "1111")then
a <= a+1;
b <= b+1;
t <= t+1;
done <= '0';
else
done <= '1';
result <= a+b;
end if;
end if;
end if;
end process;
end behave;
